[gdal-dev] Upcoming Cloud Optimized Geotiff (COG) related enhancements
Even Rouault even.rouault at spatialys.com
Fri May 3 09:43:39 PDT 2019
> About point 1, 2, 3 I have mixed feeling because to me it seems that we will
> introduce a new driver to replace the combination of gdal commands
> (disclaimer as one of the creator of rio-cogeo I may not be fully objective
> here).
Yes, the COG driver will clearly have overlap with rio-cogeo. I can imagine
that there are use cases where having it available directly as a GDAL driver
might be more convenient.
> Why this is specific to JPEG compression, what about other compressed format
> with internal mask ?
There's nothing specific indeed. This is just the main use case where internal
mask is really needed (other compression types can generally handle alpha as a
4th regular band), but yes we can generalize this optimization to any
compression type.
http://www.spatialys.com
