[gdal-dev] Upcoming Cloud Optimized Geotiff (COG) related enhancements
Vincent Sarago
vincent.sarago at gmail.com
Fri May 3 05:40:37 PDT 2019
Hi Even,
This looks great and I’m really looking for point 4 and 5.
> Le 3 mai 2019 à 04:04, Even Rouault <even.rouault at spatialys.com> a écrit :
> Hi,
> I wanted to mention COG related enhancements (*) that I will work on in GDAL
> in the coming weeks, so interested parties are aware of them and can
> potentially react.
> 1) Creation of a dedicated COG creation-only driver simplifying the creation
> workflow. Currently, creating a COG involves a number of steps, using gdaladdo
> and gdal_translate with the right arguments. For very large COG files,
> invoking gdaladdo in an efficient way can be tricky (.ovr.ovr trick: https://
> github.com/OSGeo/gdal/issues/1442). The driver will take care of creating
> needed temporary overviews.
> 2) The driver will offer integrated reprojection capabilities, and in
> particular a WebMercator/GoogleMapsCompatible tiling scheme profile (as
> defined in WMTS), so that TIFF tiles exactly match GoogleMapsCompatible ones.
> This will be similar to the corresponding option of GeoPackage. With a
> subtelty that due to how GeoTIFF overviews work, it is not possible to have
> this alignment on the tiling scheme for all zoom levels. So the user will
> define how many zoom levels starting from the full resolution image must be
> aligned (if N is the number of aligned levels, up to 2^N padding tiles in
> horizontal and vertical dimensions are needed for the full resolution image,
> so N should be kept reasonably small)
> 3) gdalwarp will be enhanced to allow output to drivers that have only
> CreateCopy() capabilities such as the COG driver. It will try to avoid
> materializing the intermediate file when possible by using VRT capabilities,
> otherwise it will have to create a temporary TIFF file before creating
> CreateCopy()
About point 1, 2, 3 I have mixed feeling because to me it seems that we will introduce a new driver to replace the combination of gdal commands (disclaimer as one of the creator of rio-cogeo I may not be fully objective here).
> 4) Optimizations specific to JPEG-compressed imagery (YCbCr color space) with
> a 1-bit transparency channel, to minimize the number of HTTP range requests
> needed to read them.
> As JPEG compression cannot include the transparency information, two TIFF IFD
> have to be created: one for YCbCr, and another one for alpha. Currently the
> COPY_SRC_OVERVIEWS=YES creation option of the GeoTIFF driver separates data
> for all the tiles of the color channels from data for all the tiles of the
> transparency channel. In practice, readers will generally want to access, for
> a same location, to data of both color and transparency channels. I will
> modify the writer to interleave blocks so that color and transparency
> information are contiguous. If COLOR_X_Y designates the tile with color
> information at coordinates X,Y (in tile coordinate space), the layout of data
> in the file will be: COLOR_0_0, TRANSPARENCY_0_0, COLOR_1_0, TRANSPARENCY_1_0,
> etc. The GeoTIFF driver will be improved to fetch together the color and
> transparency channel when such a layout is detected.
Why this is specific to JPEG compression, what about other compressed format with internal mask ?
> A further improvement is to be able to avoid completely to read the
> TileByteCount array of the color channel, and the TileByteCount & TileOffset
> arrays of the transparency channel. The trick is to reserve 4 bytes before the
> start of each COLOR_X_Y tile to indicate its size (those bytes will be
> 'ghost', that is not in the range of data pointed by TileByCount&TileOffset).
> An optimized reader wanting to read tile i=Y*nb_tiles_in_width+X will start by
> reading the offsets of tile i and i+1: TileOffset_color[i] and
> TileOffset_color[i+1]. It will then seek to TileOffset_color[i] – 4 and read 4
> + TileOffset_color[i+1] – TileOffset_color[i] bytes in a buffer. The first 4
> bytes of this buffer will indicate the number of bytes of the color tile, and
> thus it is possible to deduce the offset and size of the mask tile that is
> located at the end of the buffer. A TIFF metadata item will be written to
> indicate that such layout has been used (with an indication of the file size
> so as to be able to detect if the file has been later be altered in a non-
> optimized way), so that optimized readers can adopt the above described
> behavior. This will require to extend the libtiff interface so that the user
> can directly provide the input buffer to decompress.
> As the file will remain fully TIFF/BIGTIFF compliant, non-optimized readers
> (such as newer GDAL builds against an older external libtiff version, or
> previous GDAL versions) will still be able read it, loading values from the 4
> arrays instead of just one.
> Note: for other compressions types, a simpler version of the above
> optimization can still be done, by using TileOffset[i] and TileOffset[i+1],
> and saving the read of TileByteCount[i]
> To sum up, with the improvements of this task, once the initial loading of
> metadata has been done, a GDAL ReadBlock(x,y) request will cause only two
> networks range requests: one to read TileOffset[i] and TileOffset[i+1]
> (potentially already cached if neighboring tiles have been previously accessed
> in the same process), and another one to read the imagery (+mask) data.
> Whereas currently, 6 might be needed for JPEG YcbCr+mask.
> 5) Optimizing the layout of the header of a COG file
> The current layout of the header part of COG file is:
> - TIFF / BigTIFF signature, followed by the offset of the first IFD (Image
> File Directory)
> - IFD of full resolution image, that is the list of the tags and their value
> when it consists of a single numeric value, followed by the offset of the next
> - IFD. Its size is 2 + number_of_tags * 12 + 4 (or 2 + number_of_tags * 20 +
> 8) bytes, so typically 200 bytes maximum
> - Values of TIFF tags that don't fit inline in the IFD directory, such as
> TileOffsets and TileByteCounts arrays and GeoTIFF keys
> - IFD of first overview (typically subsampled by a factor of 2)
> - Values of its tags that don't fit inline
> -IFD of last overview
> When the COG file is not too large, the fact of having the TileOffsets and
> TileByteCounts between IFD descriptors is not an issue since they are not too
> large, and most TIFF readers will load their values when opening the IFD. But
> for an optimized reader such as GDAL with internal libtiff support (or with
> external libtiff after the optimization of task 4), loading the values of the
> TileOffsets/TileByteCounts arrays is only needed when accessing imagery.
> A more efficient layout for network access is :
> - IFD of full resolution image, followed by the value of its non-inline tags,
> except TileOffsets/TileByteCounts
> - IFD of first overview followed by the value of its non-inline tags, except
> - TileOffsets/TileByteCounts
> - IFD of last overview followed by the value of its non-inline tags, except
> - Values of the TileOffsets/TileByteCounts arrays of IFD of full resolution
> image
> - Values of the TileOffsets/TileByteCounts arrays of IFD of first overview
> - Values of the TileOffsets/TileByteCounts arrays of IFD of last overview
> With such a structure, the initial reading of 16 KB at the start of the file
> will be able to load the IFD descriptors of all overviews (and masks, which
> are actually interleaved in between when present). So, combined together with
> task 4, a cold read of a tile at any zoom level (ie opening the file + tile
> request) could result in just 3 network range requests: one to get the IFD
> descriptors at the start of the file, one to read the location of the tile
> from the TileOffsets array and one to read the tile data.
> The proposed structure itself is still fully TIFF compliant. The script that
> validates the COG structure will be adapted to accept that new variant of the
> header structure.
> Even
> (*) Funding by Land Information New Zealand / https://www.linz.govt.nz/
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190503/6b9fadde/attachment-0001.html>
