[gdal-dev] Lame question, but failing to build GDAL 3.0.0RC2 against Proj 6.0.0
Simon Eves simon.eves at omnisci.com
Tue May 7 16:42:41 PDT 2019
That's what I have, even if that's not what I wrote.
simon.eves at football:~/scratch/gdal3/gdal-3.0.0$ echo $LD_LIBRARY_PATH
/home/simon.eves/scratch/gdal3/install/lib:/usr/local/mapd-deps/lib64:/usr/local/mapd-deps/lib:/usr/local/cuda/lib64:
simon.eves at football:~/scratch/gdal3/gdal-3.0.0$ ./configure --without-geos
--with-libkml=/usr/local/mapd-deps
--with-proj=/home/simon.eves/scratch/gdal3/install
simon.eves at football:~/scratch/gdal3/gdal-3.0.0$ make
(cd apps; make)
make[1]: Entering directory '/home/simon.eves/scratch/gdal3/gdal-3.0.0/apps'
/bin/bash /home/simon.eves/scratch/gdal3/gdal-3.0.0/libtool --mode=link
--silent g++  gdalinfo_bin.lo  /home/simon.eves/scratch/gdal3/gdal-3.0.0/
libgdal.la  -o gdalinfo
/home/simon.eves/scratch/gdal3/gdal-3.0.0/.libs/libgdal.so: undefined
reference to `proj_alter_name'
[etc.]
On Tue, May 7, 2019 at 2:21 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> > The <local Proj install> path is in $LD_LIBRARY_PATH
> For $LD_LIBRARY_PATH, this should be <local Proj install>/lib
> Spatialys - Geospatial professional services
> http://www.spatialys.com
<http://www.omnisci.com/>
Simon Eves
Senior Graphics Engineer, Rendering Group
OmniSci, 1 Front St. #2650, San Francisco, CA 94111, USA
Email: simon.eves at omnisci.com | Cell:  415.902.1996
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190507/7d31da42/attachment.html>
