[gdal-dev] Lame question, but failing to build GDAL 3.0.0RC2 against Proj 6.0.0
Even Rouault
even.rouault at spatialys.com
Tue May 7 14:21:39 PDT 2019
> The <local Proj install> path is in $LD_LIBRARY_PATH
For $LD_LIBRARY_PATH, this should be <local Proj install>/lib
http://www.spatialys.com
