[gdal-dev] Lame question, but failing to build GDAL 3.0.0RC2 against Proj 6.0.0
Simon Eves
simon.eves at omnisci.com
Wed May 8 09:25:51 PDT 2019
No, it shows /usr/lib/x86_64-linux-gnu/libproj.sso.12 (the system-installed
Proj 5.2.0)
I just did it all again from scratch...
$ echo $LD_LIBRARY_PATH
/home/simon.eves/scratch/gdal3/install/lib:/usr/local/mapd-deps/lib64:/usr/local/mapd-deps/lib:/usr/local/cuda/lib64
$ cd /home/simon.eves/scratch/gdal3/
$ rm -rf gdal-3.0.0 proj-6.0.0 install/*
$ tar xzvf proj-6.0.0.tar.gz
$ cd proj-6.0.0/
$ ./configure --prefix=/home/simon.eves/scratch/gdal3/install
$ make -j12
[completes]
$ make install
[completes]
$ cd ..
$ tar xvf gdal-3.0.0rc2.tar
$ cd gdal-3.0.0/
--without-geos --with-kml=/usr/local/mapd-deps
--with-proj=/home/simon.eves/scratch/gdal3/install
[completes, shows Proj >= 6.0 yes]
$ make -j12
[fails in first app as before]
$ ldd .libs/libgdal.so | grep proj
libproj.so.12 => /usr/lib/x86_64-linux-gnu/libproj.so.12
(0x00007f3d98cb3000)
What am I doing wrong, such that the combination of $LD_LIBRARY_PATH
priority and --with-proj still isn't making GDAL see the local Proj before
the system one?
Simon
On Wed, May 8, 2019 at 12:41 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> On mardi 7 mai 2019 16:42:41 CEST Simon Eves wrote:
> > That's what I have, even if that's not what I wrote.
> > simon.eves at football:~/scratch/gdal3/gdal-3.0.0$ echo $LD_LIBRARY_PATH
> > ocal/mapd-deps/lib:/usr/local/cuda/lib64:
> > simon.eves at football:~/scratch/gdal3/gdal-3.0.0$ ./configure
> --without-geos
> > --with-libkml=/usr/local/mapd-deps
> > simon.eves at football:~/scratch/gdal3/gdal-3.0.0$ make
> > (cd apps; make)
> > make[1]: Entering directory
> '/home/simon.eves/scratch/gdal3/gdal-3.0.0/apps'
> > /bin/bash /home/simon.eves/scratch/gdal3/gdal-3.0.0/libtool --mode=link
> > --silent g++ gdalinfo_bin.lo /home/simon.eves/scratch/gdal3/gdal-3.0.0/
> > libgdal.la -o gdalinfo
> > /home/simon.eves/scratch/gdal3/gdal-3.0.0/.libs/libgdal.so: undefined
> > reference to `proj_alter_name'
> > [etc.]
> Look at the output of
> ldd /home/simon.eves/scratch/gdal3/gdal-3.0.0/.libs/libgdal.so | grep proj
> It should normally point to the libproj.so.15 of
> Spatialys - Geospatial professional services
> http://www.spatialys.com
<http://www.omnisci.com/>
Simon Eves
Senior Graphics Engineer, Rendering Group
OmniSci, 1 Front St. #2650, San Francisco, CA 94111, USA
Email: simon.eves at omnisci.com | Cell: 415.902.1996
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190508/e380e7af/attachment.html>
