[gdal-dev] Lame question, but failing to build GDAL 3.0.0RC2 against Proj 6.0.0
Simon Eves simon.eves at omnisci.com
Wed May 8 09:29:22 PDT 2019
$ ls -l /home/simon.eves/scratch/gdal3/install/lib/
total 107536
-rw-r--r-- 1 simon.eves mapd 79490260 May  8 09:06 libproj.a
-rwxr-xr-x 1 simon.eves mapd      998 May  8 09:06 libproj.la
lrwxrwxrwx 1 simon.eves mapd       17 May  8 09:06 libproj.so ->
libproj.so.15.0.0
lrwxrwxrwx 1 simon.eves mapd       17 May  8 09:06 libproj.so.15 ->
libproj.so.15.0.0
-rwxr-xr-x 1 simon.eves mapd 30610584 May  8 09:06 libproj.so.15.0.0
drwxr-xr-x 2 simon.eves mapd     4096 May  8 09:06 pkgconfig
On Wed, May 8, 2019 at 9:25 AM Simon Eves <simon.eves at omnisci.com> wrote:
> No, it shows /usr/lib/x86_64-linux-gnu/libproj.sso.12 (the
> system-installed Proj 5.2.0)
> I just did it all again from scratch...
> $ echo $LD_LIBRARY_PATH
> /home/simon.eves/scratch/gdal3/install/lib:/usr/local/mapd-deps/lib64:/usr/local/mapd-deps/lib:/usr/local/cuda/lib64
> $ cd /home/simon.eves/scratch/gdal3/
> $ rm -rf gdal-3.0.0 proj-6.0.0 install/*
> $ tar xzvf proj-6.0.0.tar.gz
> $ cd proj-6.0.0/
> $ ./configure --prefix=/home/simon.eves/scratch/gdal3/install
> $ make -j12
> [completes]
> $ make install
> [completes]
> $ cd ..
> $ tar xvf gdal-3.0.0rc2.tar
> $ cd gdal-3.0.0/
> --without-geos --with-kml=/usr/local/mapd-deps
> --with-proj=/home/simon.eves/scratch/gdal3/install
> [completes, shows Proj >= 6.0 yes]
> $ make -j12
> [fails in first app as before]
> $ ldd .libs/libgdal.so | grep proj
> libproj.so.12 => /usr/lib/x86_64-linux-gnu/libproj.so.12
> (0x00007f3d98cb3000)
> What am I doing wrong, such that the combination of $LD_LIBRARY_PATH
> priority and --with-proj still isn't making GDAL see the local Proj before
> the system one?
> Simon
> On Wed, May 8, 2019 at 12:41 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> On mardi 7 mai 2019 16:42:41 CEST Simon Eves wrote:
>> > That's what I have, even if that's not what I wrote.
>> > simon.eves at football:~/scratch/gdal3/gdal-3.0.0$ echo $LD_LIBRARY_PATH
>> > ocal/mapd-deps/lib:/usr/local/cuda/lib64:
>> > simon.eves at football:~/scratch/gdal3/gdal-3.0.0$ ./configure
>> --without-geos
>> > --with-libkml=/usr/local/mapd-deps
>> > simon.eves at football:~/scratch/gdal3/gdal-3.0.0$ make
>> > (cd apps; make)
>> > make[1]: Entering directory
>> '/home/simon.eves/scratch/gdal3/gdal-3.0.0/apps'
>> > /bin/bash /home/simon.eves/scratch/gdal3/gdal-3.0.0/libtool --mode=link
>> > --silent g++  gdalinfo_bin.lo
>> > libgdal.la  -o gdalinfo
>> > /home/simon.eves/scratch/gdal3/gdal-3.0.0/.libs/libgdal.so: undefined
>> > reference to `proj_alter_name'
>> > [etc.]
>> Look at the output of
>> ldd /home/simon.eves/scratch/gdal3/gdal-3.0.0/.libs/libgdal.so | grep proj
>> It should normally point to the libproj.so.15 of
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
> <http://www.omnisci.com/>
> Simon Eves
> Senior Graphics Engineer, Rendering Group
> OmniSci, 1 Front St. #2650, San Francisco, CA 94111, USA
> Email: simon.eves at omnisci.com | Cell:  415.902.1996
Simon Eves
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190508/9475d5ae/attachment-0001.html>
