[gdal-dev] Lame question, but failing to build GDAL 3.0.0RC2 against Proj 6.0.0
Simon Eves simon.eves at omnisci.com
Wed May 8 16:54:12 PDT 2019
I removed the system libgdal-dev and proj-bin, and then this sequence
worked, with ldd showing the local proj, and the apps all compile.
Still convinced I'm doing something stupid and n00b, but what? Why didn't
the local proj DSO take priority before?
On Wed, May 8, 2019 at 9:29 AM Simon Eves <simon.eves at omnisci.com> wrote:
> $ ls -l /home/simon.eves/scratch/gdal3/install/lib/
> total 107536
> -rw-r--r-- 1 simon.eves mapd 79490260 May  8 09:06 libproj.a
> -rwxr-xr-x 1 simon.eves mapd      998 May  8 09:06 libproj.la
> lrwxrwxrwx 1 simon.eves mapd       17 May  8 09:06 libproj.so ->
> libproj.so.15.0.0
> lrwxrwxrwx 1 simon.eves mapd       17 May  8 09:06 libproj.so.15 ->
> libproj.so.15.0.0
> -rwxr-xr-x 1 simon.eves mapd 30610584 May  8 09:06 libproj.so.15.0.0
> drwxr-xr-x 2 simon.eves mapd     4096 May  8 09:06 pkgconfig
> On Wed, May 8, 2019 at 9:25 AM Simon Eves <simon.eves at omnisci.com> wrote:
>> No, it shows /usr/lib/x86_64-linux-gnu/libproj.sso.12 (the
>> system-installed Proj 5.2.0)
>> I just did it all again from scratch...
>> $ echo $LD_LIBRARY_PATH
>> /home/simon.eves/scratch/gdal3/install/lib:/usr/local/mapd-deps/lib64:/usr/local/mapd-deps/lib:/usr/local/cuda/lib64
>> $ cd /home/simon.eves/scratch/gdal3/
>> $ rm -rf gdal-3.0.0 proj-6.0.0 install/*
>> $ tar xzvf proj-6.0.0.tar.gz
>> $ cd proj-6.0.0/
>> $ ./configure --prefix=/home/simon.eves/scratch/gdal3/install
>> $ make -j12
>> [completes]
>> $ make install
>> [completes]
>> $ cd ..
>> $ tar xvf gdal-3.0.0rc2.tar
>> $ cd gdal-3.0.0/
>> --without-geos --with-kml=/usr/local/mapd-deps
>> --with-proj=/home/simon.eves/scratch/gdal3/install
>> [completes, shows Proj >= 6.0 yes]
>> $ make -j12
>> [fails in first app as before]
>> $ ldd .libs/libgdal.so | grep proj
>> libproj.so.12 => /usr/lib/x86_64-linux-gnu/libproj.so.12
>> (0x00007f3d98cb3000)
>> What am I doing wrong, such that the combination of $LD_LIBRARY_PATH
>> priority and --with-proj still isn't making GDAL see the local Proj before
>> the system one?
>> Simon
>> On Wed, May 8, 2019 at 12:41 AM Even Rouault <even.rouault at spatialys.com>
>> wrote:
>>> On mardi 7 mai 2019 16:42:41 CEST Simon Eves wrote:
>>> > That's what I have, even if that's not what I wrote.
>>> > simon.eves at football:~/scratch/gdal3/gdal-3.0.0$ echo $LD_LIBRARY_PATH
>>> > ocal/mapd-deps/lib:/usr/local/cuda/lib64:
>>> > simon.eves at football:~/scratch/gdal3/gdal-3.0.0$ ./configure
>>> --without-geos
>>> > --with-libkml=/usr/local/mapd-deps
>>> > simon.eves at football:~/scratch/gdal3/gdal-3.0.0$ make
>>> > (cd apps; make)
>>> > make[1]: Entering directory
>>> '/home/simon.eves/scratch/gdal3/gdal-3.0.0/apps'
>>> > /bin/bash /home/simon.eves/scratch/gdal3/gdal-3.0.0/libtool --mode=link
>>> > --silent g++  gdalinfo_bin.lo
>>> > libgdal.la  -o gdalinfo
>>> > /home/simon.eves/scratch/gdal3/gdal-3.0.0/.libs/libgdal.so: undefined
>>> > reference to `proj_alter_name'
>>> > [etc.]
>>> Look at the output of
>>> ldd /home/simon.eves/scratch/gdal3/gdal-3.0.0/.libs/libgdal.so | grep
>>> proj
>>> It should normally point to the libproj.so.15 of
>>> Spatialys - Geospatial professional services
>>> http://www.spatialys.com
>> <http://www.omnisci.com/>
>> Simon Eves
>> Senior Graphics Engineer, Rendering Group
>> OmniSci, 1 Front St. #2650, San Francisco, CA 94111, USA
>> Email: simon.eves at omnisci.com | Cell:  415.902.1996
> Simon Eves
Simon Eves
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190508/38a6f9c5/attachment.html>
