[gdal-dev] Lame question, but failing to build GDAL 3.0.0RC2 against Proj 6.0.0
Jim Klassen klassen.js at gmail.com
Wed May 15 12:52:48 PDT 2019
I know I am late to the party, but I ran into the same thing today
(Building Proj 6, GDAL 3 on Debian Stretch).  I got around it by setting
LDFLAGS before running ./configure so the linker finds the proj 6
install first.  Without setting LDFLAGS, ./configure would find the new
proj, but libtool would try to link to the system one (by full path no
less, not just -lproj).
So assuming proj 6 (and GDAL) is installed in $INSTALL_DIR:
export LDFLAGS="-L${INSTALL_DIR}/lib -Wl,-rpath,${INSTALL_DIR}/lib"
./configure \
                 --prefix="${INSTALL_DIR}" \
                 --with-proj="${INSTALL_DIR}"
I'm not sure if it matters, but I also set
CMAKE_INSTALL_RPATH=$INSTALL_DIR when I build proj.
On 5/8/19 6:54 PM, Simon Eves wrote:
> I removed the system libgdal-dev and proj-bin, and then this sequence
> worked, with ldd showing the local proj, and the apps all compile.
> Still convinced I'm doing something stupid and n00b, but what? Why
> didn't the local proj DSO take priority before?
> On Wed, May 8, 2019 at 9:29 AM Simon Eves <simon.eves at omnisci.com
> <mailto:simon.eves at omnisci.com>> wrote:
>     $ ls -l /home/simon.eves/scratch/gdal3/install/lib/
>     total 107536
>     -rw-r--r-- 1 simon.eves mapd 79490260 May  8 09:06 libproj.a
>     -rwxr-xr-x 1 simon.eves mapd      998 May  8 09:06 libproj.la
>     <http://libproj.la>
>     lrwxrwxrwx 1 simon.eves mapd       17 May  8 09:06 libproj.so ->
>     libproj.so.15.0.0
>     lrwxrwxrwx 1 simon.eves mapd       17 May  8 09:06 libproj.so.15
>     -> libproj.so.15.0.0
>     -rwxr-xr-x 1 simon.eves mapd 30610584 May  8 09:06 libproj.so.15.0.0
>     drwxr-xr-x 2 simon.eves mapd     4096 May  8 09:06 pkgconfig
>     On Wed, May 8, 2019 at 9:25 AM Simon Eves <simon.eves at omnisci.com
>         No, it shows /usr/lib/x86_64-linux-gnu/libproj.sso.12 (the
>         system-installed Proj 5.2.0)
>         I just did it all again from scratch...
>         $ echo $LD_LIBRARY_PATH
>         /home/simon.eves/scratch/gdal3/install/lib:/usr/local/mapd-deps/lib64:/usr/local/mapd-deps/lib:/usr/local/cuda/lib64
>         $ cd /home/simon.eves/scratch/gdal3/
>         $ rm -rf gdal-3.0.0 proj-6.0.0 install/*
>         $ tar xzvf proj-6.0.0.tar.gz
>         $ cd proj-6.0.0/
>         $ ./configure --prefix=/home/simon.eves/scratch/gdal3/install
>         $ make -j12
>         [completes]
>         $ make install
>         [completes]
>         $ cd ..
>         $ tar xvf gdal-3.0.0rc2.tar
>         $ cd gdal-3.0.0/
>         --without-geos --with-kml=/usr/local/mapd-deps
>         --with-proj=/home/simon.eves/scratch/gdal3/install
>         [completes, shows Proj >= 6.0 yes]
>         $ make -j12
>         [fails in first app as before]
>         $ ldd .libs/libgdal.so | grep proj
>         libproj.so.12 => /usr/lib/x86_64-linux-gnu/libproj.so.12
>         (0x00007f3d98cb3000)
>         What am I doing wrong, such that the combination of
>         $LD_LIBRARY_PATH priority and --with-proj still isn't making
>         GDAL see the local Proj before the system one?
>         Simon
>         On Wed, May 8, 2019 at 12:41 AM Even Rouault
>         <even.rouault at spatialys.com
>         <mailto:even.rouault at spatialys.com>> wrote:
>             On mardi 7 mai 2019 16:42:41 CEST Simon Eves wrote:
>             > That's what I have, even if that's not what I wrote.
>             > simon.eves at football:~/scratch/gdal3/gdal-3.0.0$ echo
>             $LD_LIBRARY_PATH
>             > ocal/mapd-deps/lib:/usr/local/cuda/lib64:
>             ./configure --without-geos
>             > --with-libkml=/usr/local/mapd-deps
>             > simon.eves at football:~/scratch/gdal3/gdal-3.0.0$ make
>             > (cd apps; make)
>             > make[1]: Entering directory
>             '/home/simon.eves/scratch/gdal3/gdal-3.0.0/apps'
>             > /bin/bash
>             /home/simon.eves/scratch/gdal3/gdal-3.0.0/libtool --mode=link
>             > --silent g++  gdalinfo_bin.lo
>             > libgdal.la <http://libgdal.la> -o gdalinfo
>             /home/simon.eves/scratch/gdal3/gdal-3.0.0/.libs/libgdal.so:
>             undefined
>             > reference to `proj_alter_name'
>             > [etc.]
>             Look at the output of
>             ldd
>             | grep proj
>             It should normally point to the libproj.so.15 of
>             Spatialys - Geospatial professional services
>             http://www.spatialys.com
>         <http://www.omnisci.com/>
>         Simon Eves
>         Senior Graphics Engineer, Rendering Group
>         OmniSci, 1 Front St. #2650, San Francisco, CA 94111, USA
>         Email: simon.eves at omnisci.com
>         <mailto:simon.eves at omnisci.com> | Cell: 	415.902.1996
>     Simon Eves
>     Email: simon.eves at omnisci.com <mailto:simon.eves at omnisci.com> |
>     Cell: 	415.902.1996
> Simon Eves
> Email: simon.eves at omnisci.com <mailto:simon.eves at omnisci.com> | Cell:
> 415.902.1996
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190515/994052e1/attachment-0001.html>
