[gdal-dev] Lame question, but failing to build GDAL 3.0.0RC2 against Proj 6.0.0
Simon Eves simon.eves at omnisci.com
Tue May 28 10:16:35 PDT 2019
Confirming that setting LDFLAGS as above just for the GDAL
configure-and-build resolves the problem.
Our build guy thinks it's a little hacky, so I'd like to ask again what
changed that made this necessary.
This was all on Ubuntu 18.04, by the way. I need to try it on our other
supported Linux flavors too...
On Wed, May 15, 2019 at 12:52 PM Jim Klassen <klassen.js at gmail.com> wrote:
> I know I am late to the party, but I ran into the same thing today
> (Building Proj 6, GDAL 3 on Debian Stretch).  I got around it by setting
> LDFLAGS before running ./configure so the linker finds the proj 6 install
> first.  Without setting LDFLAGS, ./configure would find the new proj, but
> libtool would try to link to the system one (by full path no less, not just
> -lproj).
> So assuming proj 6 (and GDAL) is installed in $INSTALL_DIR:
> export LDFLAGS="-L${INSTALL_DIR}/lib -Wl,-rpath,${INSTALL_DIR}/lib"
> ./configure \
>                 --prefix="${INSTALL_DIR}" \
>                 --with-proj="${INSTALL_DIR}"
> I'm not sure if it matters, but I also set
> CMAKE_INSTALL_RPATH=$INSTALL_DIR when I build proj.
> On 5/8/19 6:54 PM, Simon Eves wrote:
> I removed the system libgdal-dev and proj-bin, and then this sequence
> worked, with ldd showing the local proj, and the apps all compile.
> Still convinced I'm doing something stupid and n00b, but what? Why didn't
> the local proj DSO take priority before?
> On Wed, May 8, 2019 at 9:29 AM Simon Eves <simon.eves at omnisci.com> wrote:
>> $ ls -l /home/simon.eves/scratch/gdal3/install/lib/
>> total 107536
>> -rw-r--r-- 1 simon.eves mapd 79490260 May  8 09:06 libproj.a
>> -rwxr-xr-x 1 simon.eves mapd      998 May  8 09:06 libproj.la
>> lrwxrwxrwx 1 simon.eves mapd       17 May  8 09:06 libproj.so ->
>> libproj.so.15.0.0
>> lrwxrwxrwx 1 simon.eves mapd       17 May  8 09:06 libproj.so.15 ->
>> libproj.so.15.0.0
>> -rwxr-xr-x 1 simon.eves mapd 30610584 May  8 09:06 libproj.so.15.0.0
>> drwxr-xr-x 2 simon.eves mapd     4096 May  8 09:06 pkgconfig
>> On Wed, May 8, 2019 at 9:25 AM Simon Eves <simon.eves at omnisci.com> wrote:
>>> No, it shows /usr/lib/x86_64-linux-gnu/libproj.sso.12 (the
>>> system-installed Proj 5.2.0)
>>> I just did it all again from scratch...
>>> $ echo $LD_LIBRARY_PATH
>>> /home/simon.eves/scratch/gdal3/install/lib:/usr/local/mapd-deps/lib64:/usr/local/mapd-deps/lib:/usr/local/cuda/lib64
>>> $ cd /home/simon.eves/scratch/gdal3/
>>> $ rm -rf gdal-3.0.0 proj-6.0.0 install/*
>>> $ tar xzvf proj-6.0.0.tar.gz
>>> $ cd proj-6.0.0/
>>> $ ./configure --prefix=/home/simon.eves/scratch/gdal3/install
>>> $ make -j12
>>> [completes]
>>> $ make install
>>> [completes]
>>> $ cd ..
>>> $ tar xvf gdal-3.0.0rc2.tar
>>> $ cd gdal-3.0.0/
>>> --without-geos --with-kml=/usr/local/mapd-deps
>>> --with-proj=/home/simon.eves/scratch/gdal3/install
>>> [completes, shows Proj >= 6.0 yes]
>>> $ make -j12
>>> [fails in first app as before]
>>> $ ldd .libs/libgdal.so | grep proj
>>> libproj.so.12 => /usr/lib/x86_64-linux-gnu/libproj.so.12
>>> (0x00007f3d98cb3000)
>>> What am I doing wrong, such that the combination of $LD_LIBRARY_PATH
>>> priority and --with-proj still isn't making GDAL see the local Proj before
>>> the system one?
>>> Simon
>>> On Wed, May 8, 2019 at 12:41 AM Even Rouault <even.rouault at spatialys.com>
>>> wrote:
>>>> On mardi 7 mai 2019 16:42:41 CEST Simon Eves wrote:
>>>> > That's what I have, even if that's not what I wrote.
>>>> > simon.eves at football:~/scratch/gdal3/gdal-3.0.0$ echo $LD_LIBRARY_PATH
>>>> > ocal/mapd-deps/lib:/usr/local/cuda/lib64:
>>>> > simon.eves at football:~/scratch/gdal3/gdal-3.0.0$ ./configure
>>>> --without-geos
>>>> > --with-libkml=/usr/local/mapd-deps
>>>> > simon.eves at football:~/scratch/gdal3/gdal-3.0.0$ make
>>>> > (cd apps; make)
>>>> > make[1]: Entering directory
>>>> '/home/simon.eves/scratch/gdal3/gdal-3.0.0/apps'
>>>> > /bin/bash /home/simon.eves/scratch/gdal3/gdal-3.0.0/libtool
>>>> --mode=link
>>>> > --silent g++  gdalinfo_bin.lo
>>>> > libgdal.la  -o gdalinfo
>>>> > /home/simon.eves/scratch/gdal3/gdal-3.0.0/.libs/libgdal.so: undefined
>>>> > reference to `proj_alter_name'
>>>> > [etc.]
>>>> Look at the output of
>>>> ldd /home/simon.eves/scratch/gdal3/gdal-3.0.0/.libs/libgdal.so | grep
>>>> proj
>>>> It should normally point to the libproj.so.15 of
>>>> Spatialys - Geospatial professional services
>>>> http://www.spatialys.com
>>> <http://www.omnisci.com/>
>>> Simon Eves
>>> Senior Graphics Engineer, Rendering Group
>>> OmniSci, 1 Front St. #2650, San Francisco, CA 94111, USA
>>> Email: simon.eves at omnisci.com | Cell:  415.902.1996
>> Simon Eves
> Simon Eves
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
Simon Eves
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190528/03d51f25/attachment-0001.html>
