[gdal-dev] Building GDAL 3.0.0 with Proj 6.0.0
Jim Klassen
klassen.js at gmail.com
Wed May 15 13:38:08 PDT 2019
Did you set ./configure --with-proj=${INSTALL_DIR}?
Where INSTALL_DIR is the install directory (prefix) of proj/gdal.
I also had to set:
export LDFLAGS="-L${INSTALL_DIR}/lib -Wl,-rpath,${INSTALL_DIR}/lib"
to get gdal to actually link against the new proj (vs the system
installed one).
On 5/15/19 3:27 PM, joshl wrote:
> Hello,
> I'm having trouble getting gdal to build with proj on linux. They are both
> brought in as git submodules in a git repo and get built via cmake.
> To get proj 6.0.0 to build, I had to add a small modification to its
> CMakeLists.txt where it uses both the src and include folders for the
> include_directories command (did not have include folder originally):
> /include_directories(${PROJ4_SOURCE_DIR}/src ${PROJ4_SOURCE_DIR}/include)/
> If I don't do this it will error with the following since proj/common.hpp is
> in the include folder:
> <proj path>/src/proj_internal.h:61:27: fatal error: proj/common.hpp: No such
> file or directory
> For gdal, an error occurs during the configure step. If I manually run our
> configure command (or a stripped down version just using just -with-proj)
> in the gdal dir, it will fail trying to find symbols for proj:
> checking for PROJ >= 6 library... checking for proj_create_from_wkt in
> -lproj... no
> checking for proj_create_from_wkt in -lproj... no
> checking for internal_proj_create_from_wkt in -lproj... no
> checking for internal_proj_create_from_wkt in -linternalproj... no
> checking for internal_proj_create_from_wkt in -linternalproj... (cached) no
> configure: error: PROJ 6 symbols not found
> A similar failure is seen on this stack exchange post here:
> https://gis.stackexchange.com/questions/317109/build-gdal-with-proj-version-6
> The most common solution I found googling around seems to be using
> --with-static-proj4 but that is no longer recognized as a configure script
> option in gdal 3. I checked out the commit hash for gdal 2.4.1 and tried to
> use --with-static-proj4 but I got the same error.
> A team member had suggested that maybe proj wasn't built with all the
> necessary features for gdal so it can't find those require symbols...
> Not sure what the right move is from here so any suggestions are
> appreciated.
> -Josh
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
