[gdal-dev] Building GDAL 3.0.0 with Proj 6.0.0
joshl
josh at cesium.com
Thu May 16 07:53:44 PDT 2019
Tried doing the LDFLAGS export but got the same errors. My full manual
./configure command (just running on command line) that I'm testing (to at
least get past this error) in the gdal git submodule dir is here:
*projInstallDir*='/home/loshjawrence/clonesRedo/agi-asset-pipeline/build/ThirdParty/proj.4'
*gdalInstallDir*='/home/loshjawrence/clonesRedo/agi-asset-pipeline/build/ThirdParty/gdal'
export LDFLAGS="-L$*projInstallDir*/lib -Wl,-rpath,$*projInstallDir*/lib"
./configure \
--with-proj=$*projInstallDir*/lib \
--prefix=$*gdalInstallDir*
James Klassen-2 wrote
> export LDFLAGS="-L${INSTALL_DIR}/lib -Wl,-rpath,${INSTALL_DIR}/lib"
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
