[gdal-dev] Does /vsis3 work for HDF4?
James McClain
jmcclain at azavea.com
Mon May 20 12:35:35 PDT 2019
Hello,
I don't believe that it does currently.
Originally, support for HDF5 and NetCDF both used the cpl_userfaultfd
mechanism
https://github.com/OSGeo/gdal/blob/master/gdal/port/cpl_userfaultfd.cpp).
The thing that prevented HDF4 from using that mechanism was that its
underlying library did not have the ability to operate on a block of memory
(the cpl_userfaultfd provides a user-mode page fault handler that fills
pages on demand using the VSI mechanism).
It is my recollection that a more direct method was found for HDF5 so that
it no longer uses cpl_userfaultfd; perhaps a similarly more direct
mechanism exists in HDF4? I do not know whether it does or does not.
Sincerely,
James McClain
On Mon, May 20, 2019 at 2:45 PM Joe Lee <hyoklee at hdfgroup.org> wrote:
> Hi,
> I have a quick question.
> I know that /vsis3 work for HDF5.
> How about HDF4?
> Does /vsis3 also work for HDF4?
> Regards,
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
James McClain
Software Developer
Azavea | 990 Spring Garden Street, 5th Floor, Philadelphia, PA 19123
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190520/8744bdd3/attachment.html>
