[gdal-dev] Does /vsis3 work for HDF4?
Even Rouault
even.rouault at spatialys.com
Tue May 21 13:29:11 PDT 2019
> How about HDF4?
> Does /vsis3 also work for HDF4?
Not directly, as to the best of my knowledge, but you're likely more in a
postion o confirm, libhdf4 has no I/O abstraction layer.
On Linux, you might try the vsipreload trick:
https://lists.osgeo.org/pipermail/gdal-dev/2013-May/036359.html
Even
http://www.spatialys.com
