[gdal-dev] gdal raster gpkg CreateCopy create tiles for no data area
redheli
zhiyong.weng at gmail.com
Tue May 21 21:44:57 PDT 2019
I have a raster gpkg with only two tiles (size 1000x1000 meter),
one tile is locate in Singapore, and the second tile is in Boston.
so the problem happen, when try to use CreateCopy (C++ gdal 2.4.0) to append
the above gpkg to another one.
the CreateCopy try to create all tiles between Singapore and Boston, and it
takes forever.
Is it the expected behavior of "CreateCopy"?
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
