[gdal-dev] What is the correct way to call OSRSetPROJSearchPaths?
CDelancy
cdelancy at blackfangtechnologies.com
Fri May 31 03:41:45 PDT 2019
Using GDAL 3 and PROJ 6, it seems this is the function I must call to point
proj to the location of the proj.db file it needs. However, any time I call
this function, it results in an access violation.
Does anyone have an example of how to call this?
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
