[gdal-dev] What is the correct way to call OSRSetPROJSearchPaths?
Even Rouault
even.rouault at spatialys.com
Fri May 31 04:00:49 PDT 2019
On vendredi 31 mai 2019 03:41:45 CEST CDelancy wrote:
> Using GDAL 3 and PROJ 6, it seems this is the function I must call to point
> proj to the location of the proj.db file it needs. However, any time I call
> this function, it results in an access violation.
Is the array of strings you provide as argument terminated by a NULL pointer ?
> Does anyone have an example of how to call this?
https://github.com/OSGeo/gdal/blob/master/autotest/cpp/
test_osr_set_proj_search_paths.cpp
http://www.spatialys.com
