[gdal-dev] How to Set DXF_FEATURE_LIMIT_PER_BLOCK in ogr2ogr?
Even Rouault
even.rouault at spatialys.com
Sun Nov 3 01:24:18 PST 2019
> How do I do this? When I type: DXF_FEATURE_LIMIT_PER_BLOCK=-1,
> DXF_FEATURE_LIMIT_PER_BLOCK -1, - DXF_FEATURE_LIMIT_PER_BLOCK=-1, --
> DXF_FEATURE_LIMIT_PER_BLOCK -1, and all the variations of the = and -
> before DXF_FEATURE_LIMIT_PER_BLOCK, I get an "Unknown option name
> DXF_FEATURE_LIMIT_PER_BLOCK".
--> https://gdal.org/programs/vector_common_options.html#cmdoption-config
http://www.spatialys.com
