[gdal-dev] NetCDF and ESA Probav issue with corner coordimates
Jacobs Tim tim.jacobs at vito.be
Mon Nov 4 00:26:27 PST 2019
Dear GDAL experts,
Working for the provider of the PROBA-V data, I can confirm that
the intention is to have a grid with integer degrees at pixel centre.
So the -180.00xxx (half pixel west of -180) reported by gdalinfo for upperleft corner of upperleft pixel is fine,
though we realize that this gridding can cause trouble when using it in practice (e.g. GRASS GIS warns about it).
We typically provide data in both generic container (HDF5 and more recently netCDF4)
as well as GeoTIFF format (for GIS).
@Ivan - to contact our support service, please email helpdeskticket at vgt.vito.be<mailto:helpdeskticket at vgt.vito.be>.
Best regards,
Tim Jacobs
Indien u VITO Mol bezoekt, hou aub er dan rekening mee dat de hoofdingang voortaan enkel bereikbaar is vanuit de richting Dessel-Retie, niet vanuit richting Mol, zie vito.be/route.<http://www.vito.be/route>
If you plan to visit VITO at Mol, then please note that the main entrance can only be reached coming from Dessel-Retie and no longer coming from Mol, see vito.be/en/contact/locations.<http://www.vito.be/en/contact/locations>
VITO Disclaimer: http://www.vito.be/e-maildisclaimer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191104/696ab17c/attachment.html>
