[gdal-dev] FileGDB & FID
Mike mswope at gmail.com
Tue Nov 5 12:16:36 PST 2019
I did end up just defining the layers and just adding all the data to it.
However this does occur with ogr2ogr, and it says to use skip failures.
When I use that, I get one less feature (fails on the first I assume).
Is there a way to ignore FID with fgdb output & ogr2ogr?
Same for the CopyLayer in python.
On Tue, Nov 5, 2019, 12:29 mike Null <gdisk.mike at gmail.com> wrote:
> I'm trying to create some features in a File GDB, and have that driver
> loaded.
> I've been doing something along the lines just fine to gpkg, but I hit a
> FileGDB issue and wondering how to get around it.
> This line in python
> lyr = fgdbds.CopyLayer(inmemorylayer,somename,['OVERWRITE=YES'])
> I get the issue
> ERROR 6: Only 32 bit positive integers FID supported by FileGDB
> How can I get around this?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191105/06c4ca9d/attachment.html>
