[gdal-dev] FileGDB & FID
Even Rouault
even.rouault at spatialys.com
Tue Nov 5 12:27:46 PST 2019
On mardi 5 novembre 2019 13:16:36 CET Mike wrote:
> I did end up just defining the layers and just adding all the data to it.
> However this does occur with ogr2ogr, and it says to use skip failures.
> When I use that, I get one less feature (fails on the first I assume).
You get that message because one of your ids doesn't fit on 32 bit
CopyLayer() is quite limited regarding is options.
You could use the gdal.VectorTranslate() which is the function behind ogr2ogr.
Then you can use the -unsetFid and/or -skip options
Even
http://www.spatialys.com
