[gdal-dev] ogr2ogr PDF
paul.malm at lfv.se
paul.malm at lfv.se
Sun Nov 10 23:45:31 PST 2019
Thanks Andreas,
Yes, I would like to automate it. I have read the page you suggested but I don’t understand how to implement it with ogr2ogr.
Kind regards,
Paul
Från: Andreas Neumann [mailto:a.neumann at carto.net]
Skickat: den 11 november 2019 08:35
Till: Malm, Paul (Operations AIM)
Kopia: gdal-dev at lists.osgeo.org
Ämne: Re: [gdal-dev] ogr2ogr PDF
Hi Paul,
ogr2ogr usually doesn't care much about styling, unless you use ogr feature styles:
https://svn.osgeo.org/gdal/trunk/gdal/ogr/ogr_feature_style.html
Or you use QGIS 3.10* which has a nice GeoPDF export built in. But if you want to automate things, I understand that the automated solution might be better for your workflow.
*Disclaimer: QGIS 3.10 must be compiled with GDAL >= 3.0 and proj6, which as far as I know is currently not the case for QGIS Windows standalone builds. See also https://gis.stackexchange.com/questions/340030/create-geospatial-pdf-geopdf-is-greyed-out-in-pdf-export-options-in-qgis-3-10
Greetings,
Andreas
On 2019-11-11 08:28, paul.malm at lfv.se wrote:
Hi list,
I have a question on how to export a PDF file from PostGIS with a color on the lines instead of the default black lines. I have searched on the internet but have not reached all the way…
I have 2 tables that I would like to export into test.pdf (rivers and roads)
ogr2ogr -f "PDF" c:\Temp\test.pdf PG:"host=xxx.xxx.xxx.x user=yyyy dbname=testdb password=pwd" rivers roads
I would, for instance set like to set line width to 1 px and color to 4040FF on rivers,
Width 3 px and color FF4040 on roads.
Thanks,
Paul
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191111/209e3c04/attachment-0001.html>
