[gdal-dev] ogr2ogr PDF
Andreas Neumann a.neumann at carto.net
Sun Nov 10 23:34:52 PST 2019
Hi Paul,
ogr2ogr usually doesn't care much about styling, unless you use ogr
feature styles:
https://svn.osgeo.org/gdal/trunk/gdal/ogr/ogr_feature_style.html
Or you use QGIS 3.10* which has a nice GeoPDF export built in. But if
you want to automate things, I understand that the automated solution
might be better for your workflow.
*Disclaimer: QGIS 3.10 must be compiled with GDAL >= 3.0 and proj6,
which as far as I know is currently not the case for QGIS Windows
standalone builds. See also
https://gis.stackexchange.com/questions/340030/create-geospatial-pdf-geopdf-is-greyed-out-in-pdf-export-options-in-qgis-3-10
Greetings,
Andreas
On 2019-11-11 08:28, paul.malm at lfv.se wrote:
> Hi list,
> I have a question on how to export a PDF file from PostGIS with a color on the lines instead of the default black lines. I have searched on the internet but have not reached all the way…
> I have 2 tables that I would like to export into test.pdf (rivers and roads)
> ogr2ogr -f "PDF" c:\Temp\test.pdf PG:"host=xxx.xxx.xxx.x user=yyyy dbname=testdb password=pwd" rivers roads
> I would, for instance set like to set line width to 1 px and color to 4040FF on rivers,
> Width 3 px and color FF4040 on roads.
> Thanks,
> Paul
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191111/7fcead42/attachment.html>
