[gdal-dev] gdalbuildvrt issues
Even Rouault
even.rouault at spatialys.com
Mon Nov 11 08:27:31 PST 2019
On lundi 11 novembre 2019 16:14:34 CET Joaquim Manuel Freire Luís wrote:
> Hi,
> I'm facing strange things when using gdalbuildvrt. First, with my own build
> (GDAL master) I can't use wild cards (Windows here)
You probably need to define the following in your nmake.local:
# To be enabled defined to point to wsetargv.obj from the Visual C++
directory,
# when you want the utility programs to be able to expand wildcards.
#SETARGV = "D:\Software\VStudio\VC98\lib\wsetargv.obj"
Note: regular setargv.obj might also work.
> But is not the worst. The worst is that when I look into the VRT file I see
> this. Notice how the SrcRect and DstRect differ. Why is that?
I suspect you're mosaicing files of different resolutions.
Even
http://www.spatialys.com
