[gdal-dev] gdalbuildvrt issues
Joaquim Manuel Freire Luís jluis at ualg.pt
Mon Nov 11 08:36:44 PST 2019
You probably need to define the following in your nmake.local:
># To be enabled defined to point to wsetargv.obj from the Visual C++ directory, # when you want >the utility programs to be able to expand wildcards.
>#SETARGV =      "D:\Software\VStudio\VC98\lib\wsetargv.obj"
>Note: regular setargv.obj might also work.
Thanks. After writing the mail I remembered that we also used to have something like that in the old GMT building (pre CMake)
>> But is not the worst. The worst is that when I look into the VRT file
>> I see this. Notice how the SrcRect and DstRect differ. Why is that?
> I suspect you're mosaicing files of different resolutions.
Yes, also found that (after). It's the panchromatic band 8 of the LandSat8 set, which has double resolution. But in this case, shouldn't the -separate option make a difference? But it doesn't. The result is the same either if I use it or not (confess that I don't understand the meaning of this option)
