[gdal-dev] ogr2ogr PDF
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Wed Nov 13 07:35:18 PST 2019
What is supported is documented in a table in
https://gdal.org/drivers/raster/pdf.html. For PEN only these options are
supported: color (c); width (w); dash pattern (p).
So why, you know, nobody has implemented it yet. Meanwhile you can do
something with dash pattern, or edit the PDF with some PDF editor.
-Jukka Rahkonen-
paul.malm wrote
> Hi,
> I’m now setting attribute OGR_STYLE in my postGis db for a testlayer
> (line)
> I’m now setting attribute OGR_STYLE in my postgis db for a test layer
> (LineString):
> … SET \"OGR_STYLE\"= 'PEN(c:#FF3333,id:ogr-pen-4,w:1px)'
> Does anyone know why the pen symbol (id) is ignored when exporting the
> PDF, it’s always a solid line?
> Color and width is ok.
> I’ve tried to draw a ogr-symbol together with a point layer and it worked
> like a charm.
> Kind regards,
> Paul
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
