[gdal-dev] Discrepancy when tiling on MAC and Linux
Even Rouault
even.rouault at spatialys.com
Thu Nov 14 03:46:56 PST 2019
On jeudi 14 novembre 2019 05:54:09 CET Grégory Bataille wrote:
> wow, thanks.
> I'm not quite sure I'm following it all though. I'm reaching a bit my
> knowledge limit here with those transforms. I'll need to spend a bit more
> time on it to get more understanding and see what I can do, how I might use
> your update.
> But thanks for the quick turnaround
Another option if you want full control on the transformation would be to
provide the PROJ pipeline directly. gdalwarp has the -ct switch for that,
which ultimately uses OGRCoordinateTransformation::SetCoordinateOperation()
Even
http://www.spatialys.com
