[gdal-dev] Discrepancy when tiling on MAC and Linux
Grégory Bataille
gregory.bataille at gmail.com
Thu Nov 14 04:03:34 PST 2019
Oh, I could gdalwarp the dataset myself to WGS84 and then tile it, so as to
consistently "ignore" grids.
That's an idea indeed.
Thanks for the pointer, I'll take it into consideration
Gregory Bataille
On Thu, Nov 14, 2019 at 12:46 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 14 novembre 2019 05:54:09 CET Grégory Bataille wrote:
> > wow, thanks.
> > I'm not quite sure I'm following it all though. I'm reaching a bit my
> > knowledge limit here with those transforms. I'll need to spend a bit more
> > time on it to get more understanding and see what I can do, how I might
> use
> > your update.
> > But thanks for the quick turnaround
> Another option if you want full control on the transformation would be to
> provide the PROJ pipeline directly. gdalwarp has the -ct switch for that,
> which ultimately uses OGRCoordinateTransformation::SetCoordinateOperation()
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191114/a223eb51/attachment.html>
