[gdal-dev] Source pixels used when warping using cubic resampling
Even Rouault
even.rouault at spatialys.com
Fri Nov 15 10:37:53 PST 2019
On vendredi 25 octobre 2019 16:02:57 CET Gregory, Matthew wrote:
> Hi all,
> I am warping and upsampling an image from 4km to 30m using cubic resampling.
> I've been warping different sized windows from the source image like this:
> # Larger window
> gdalwarp
> -t_srs EPSG:5070
> -te -2303985 2406015 -2033985 2649015
> -tr 30 30
> -of GTiff
> -r cubic
> in.vrt
> out.tif
> # Single line of above window
> gdalwarp
> -t_srs EPSG:5070
> -te -2303985 2648985 -2033985 2649015
> -tr 30 30
> -of GTiff
> -r cubic
> in.vrt
> line.tif
> Naively, my expectation was that the overlap region would have identical
> values, but they don't. I assume this means that the source (4km) pixels
> are being subset down to a smaller window before warping in the latter case
> that don't necessarily include the same 16 nearest pixels as in the first
> case? I had a brief look through the Warp API tutorial and it looks like
> it may have something to do with the GDALSuggestedWarpOutput, but I didn't
> dig too deeply there.
maybe try to add
-et 0
and/or
-wo XSCALE=133.33333333333334 -wo YSCALE=133.33333333333334
where 133.3333 = 4000 / 30
XSCALE/YSCALE are "un-documented" there:
https://github.com/OSGeo/gdal/blob/master/gdal/alg/gdalwarpkernel.cpp#L1120
http://www.spatialys.com
