[gdal-dev] Compile problems gdal3.0.2 against proj6
Andreas Neumann a.neumann at carto.net
Tue Nov 19 05:49:14 PST 2019
Hi Even,
Yes - you are right. Other gdal library dependencies still link to the
old version.
I will the trick at
https://trac.osgeo.org/gdal/wiki/BuildingOnUnixGDAL25dev first, before I
try the harder way to recompile all other packages.
Thanks,
Andreas
On 2019-11-19 14:28, Even Rouault wrote:
> Andreas,
>> So this seems like it links to the old version of proj. Why is using
>> this one if I specified "--with-proj=/usr/local" ?
> GDAL build system doesn't use rpath mechanism for linking, so if there are
> several libproj.so in the path used for linking it will use the first or last
> one, I never remember :-).
> Anyway, even if you manage to build, you're bound to run into runtime problems
> if you intend to link GDAL against PROJ 6 and spatialite built against an
> older PROJ.
> So 2 ways:
> - uninstall the proj development package, and build spatialite against proj6
> too
> - or use the trick at https://trac.osgeo.org/gdal/wiki/BuildingOnUnixGDAL25dev
> Even
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191119/4656d472/attachment-0001.html>
