[gdal-dev] PDF: configure option --enable-pdf-plugin
Andreas Neumann a.neumann at carto.net
Wed Nov 20 00:42:22 PST 2019
I wonder what exactly the build option "--enable-pdf-plugin enable PDF
driver as a plugin (included in libgdal by default)" means?
How does this relate to the other options of building against
poppler/podofo/pdfium ?
Thank you very much if you have more information,
Andreas
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191120/ae3aec7f/attachment.html>
