[gdal-dev] PDF: configure option --enable-pdf-plugin
Even Rouault
even.rouault at spatialys.com
Wed Nov 20 02:08:58 PST 2019
Andreas,
> I wonder what exactly the build option "--enable-pdf-plugin enable PDF
> driver as a plugin (included in libgdal by default)" means?
Plugin here means as a separate .so/.dll : gdal_PDF.so/dll
Mostly for licensing concerns if using the Poppler backend since Poppler is
subject to the GPL. So you can make a libgdal build mostly subject to X/MIT or
similar licenses, and in case you need it, use a gdal_PDF plugin subject to
GPL
> How does this relate to the other options of building against
> poppler/podofo/pdfium ?
It is orthogonal to the poppler/podofo/pdfium backend(s) used.
For the pdfium backend, which is a bit involved to build (pdfium actually),
there were also issues with symbol clashes between embedded libraries in
pdfium and others used by GDAL, and making a plugin instead of linking in core
GDAL library seemed to "solve" (workaround) issues. Was at least true on Linux
with pdfium of a few years ago. I don't remember having had such issues with
the recent upgrade I did in GDAL master.
Even
http://www.spatialys.com
