[gdal-dev] PDF: configure option --enable-pdf-plugin
Andreas Neumann
a.neumann at carto.net
Wed Nov 20 02:50:40 PST 2019
Hi Even,
Thanks for the clarification. In that case I don't need to build it as a
plugin, since this build will only end up on my own local machine.
Andreas
On 2019-11-20 11:08, Even Rouault wrote:
> Andreas,
>> I wonder what exactly the build option "--enable-pdf-plugin enable PDF
>> driver as a plugin (included in libgdal by default)" means?
> Plugin here means as a separate .so/.dll : gdal_PDF.so/dll
> Mostly for licensing concerns if using the Poppler backend since Poppler is
> subject to the GPL. So you can make a libgdal build mostly subject to X/MIT or
> similar licenses, and in case you need it, use a gdal_PDF plugin subject to
> GPL
>> How does this relate to the other options of building against
>> poppler/podofo/pdfium ?
> It is orthogonal to the poppler/podofo/pdfium backend(s) used.
> For the pdfium backend, which is a bit involved to build (pdfium actually),
> there were also issues with symbol clashes between embedded libraries in
> pdfium and others used by GDAL, and making a plugin instead of linking in core
> GDAL library seemed to "solve" (workaround) issues. Was at least true on Linux
> with pdfium of a few years ago. I don't remember having had such issues with
> the recent upgrade I did in GDAL master.
> Even
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191120/f6837934/attachment.html>
