[gdal-dev] GDAL tools that are Python scripts still need Python2 in OSGeo4W
Pedro VenĂ¢ncio pedrongvenancio at gmail.com
Wed Nov 20 04:40:49 PST 2019
Hi all,
I've a clean OSGeo4W install and I was trying to use some GDAL tools like
gdal2xyz or rgb2pct, but I was getting an error of missing module in
Python3:
python3 -m rgb2pct -n 2 -of GTiff D:\orto_teste.tif D:/orto_teste_pct.tif
GDAL command output:
C:\OSGEO4~1\bin\python3.exe: No module named rgb2pct
To overcome this issue, I had to install gdal-python, that still has
Python2 as dependency.
Where should this issue be solved? In GDAL or in OSGeo4W?
Thank you very much!
Best regards,
Pedro VenĂ¢ncio
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191120/60720938/attachment.html>
