[gdal-dev] arcsde
Jachym Cepicky jachym.cepicky at gmail.com
Mon Nov 25 00:47:52 PST 2019
Thank you Even, will look into it
Removing SDE from list of supported formats makes sense
J
pá 22. 11. 2019 v 21:42 odesílatel Even Rouault
<even.rouault at spatialys.com> napsal:
> Jachym,
> Some more info at https://trac.osgeo.org/gdal/wiki/ArcSDE
> from what I remember from noise captured here and there during last years:
> - ESRI has stopped distributing the ArcSDE SDK in "recent" versions. So you have to
> be one the "happy few" that have still a copy of it to be able to - try to - compile the driver
> - looking at the commit history, the person who has last pushed a fix in this
> driver, and presumably compiled it while doing so, was Tamas in 2012. Since
> then all commits into it have likely been done in a blind way (grep-style replacement, etc)
> Perhaps it still builds, by chance... ?
> Not GDAL, but you might find it interesting to read:
> https://knowledge.safe.com/articles/73399/esri-legacy-arcsde-sde30-deprecation.html
> Probably this driver and its raster counterpart should just be removed.
> Unless someone says "eh I still use it, it compiles and runs fine"
> Good luck !
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
