[gdal-dev] Adding Features to Existing PostIGIS Table with Python OGR/GDAL?
Thomas Juntunen
junt0015 at umn.edu
Mon Nov 25 13:29:28 PST 2019
Hi Gerard,
Your first example is trying to make a new layer (table), and since
trackslayer exists, and you selected overwrite is NO, it raises an error
because you're trying to replace the table. If you are adding features to
an existing table, your second method is the way to do it. You only need
CreateLayer for new tables.
On Mon, Nov 25, 2019 at 3:00 PM Gerard <gerardg at gmail.com> wrote:
> Thanks!
> def Open(*args, **kwargs):
> """Open(char const * utf8_path, int update=0) -> DataSource"""
> return _ogr.Open(*args, **kwargs)
> This still causes an error, even though OVERWRITE is set to NO.
> ds = ogr.Open("PG:dbname='db' user='user'", update=1)
> trackslayer = ds.CreateLayer(table, srs, ogr.wkbMultiLineString,
> ['OVERWRITE=NO'] )
> However, this seems to work fine:
> trackslayer = ds.GetLayerByName('tracks')
> tracksdef = trackslayer.GetLayerDefn()
> outFeature = ogr.Feature(tracksdef)
> outFeature.SetField("name", name)
> trackslayer.CreateFeature(outFeature)
> Gerard
> On Mon, Nov 25, 2019 at 11:24 AM Thomas Juntunen <junt0015 at umn.edu> wrote:
>> Gerard,
>> You need to open your data source in update mode.
>> On Mon, Nov 25, 2019 at 10:58 AM Gerard <gerardg at gmail.com> wrote:
>>> Is it possible to add features to an existing PostGIS table using Python
>>> OGR/GDAL? I've tried these two approaches:
>>> # Approach 1. Results in:
>>> # ERROR 1: Layer tracks already exists, CreateLayer failed.
>>> # Use the layer creation option OVERWRITE=YES to replace it.
>>> ds = ogr.Open("PG:dbname='db' user='user'")
>>> srs = osr.SpatialReference()
>>> srs.ImportFromEPSG(4326)
>>> layer = ds.CreateLayer('tracks', srs, ogr.wkbMultiLineString,
>>> ['OVERWRITE=NO'] )
>>> # Approach 2. Results in:
>>> # ERROR 1: Invalid index : -1
>>> # ERROR 6: CreateFeature : unsupported operation on a read-only
>>> datasource.
>>> # set fields, etc.
>>> Think I could accomplish it via SQL statements and ds.ExecuteSQL(), and
>>> I've found examples using psycopg2 (or SQLAlchemy) instead. Just wondering
>>> if it's directly possible using Python OGR/GDAL.
>>> Thanks,
>>> Gerard
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> *The right coordinate system can turn an impossible problem into two
>> really hard problems. -- Charlie Pellerin*
>> Thomas Juntunen
>> GIS Specialist
>> Polar Geospatial Center
>> R280 Learning and Environmental Science
>> 1954 Buford Ave
>> University of Minnesota
>> St. Paul, MN 55108
>> 612-626-0505
*The right coordinate system can turn an impossible problem into two really
Thomas Juntunen
GIS Specialist
1954 Buford Ave
St. Paul, MN 55108
612-626-0505
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191125/2171ef41/attachment.html>
