[gdal-dev] Export a geotiff to netcdf in lat lon coordinates
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Nov 25 14:44:22 PST 2019
Hi Tony,
When I execute 'ncdump -h' locally on your generated file I get a proper
response (see https://pastebin.com/Ki4BTTNS). Note that MS4W is
currently built against netCDF-4.7.0 (maybe you have an older netCDF
library version?)
PS. I'll shortly be upgrading netCDF support to the recent 4.7.3 release
for Windows users (follow along if you wish at
https://ms4w.com/trac/ticket/238)
Hope that helps.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2019-11-25 4:11 PM, Tony L. wrote:
> Hello Jeff!
> Thank you so much for your help!!
> I tried to follow your steps and works well for the transformation from
> tif to netcdf. I can use ncdump to check info on the file and I can plot
> it normally.
> Now, when I reproject the file to lat/lon coord using your command:
> gdalwarp -s_srs EPSG:3411 -t_srs EPSG:4326
> N_197901_concentration_v3.0.nc N_197901_concentration_v3.0_4326.nc
> and when I try to get info on the file using ncdump -h I get:
> ncdump: N_197901_concentration_v3.0_4326.nc: NetCDF: Unknown file format
> Any idea as to why that would happen?
> Tony
> On Friday, November 22, 2019, 01:19:50 PM EST, Jeff McKenna
> <jmckenna at gatewaygeomatics.com> wrote:
> Hi Tony,
> Here are my steps.
> Have a nice weekend.
> #use gdalinfo to get summary (see https://gdal.org/programs/gdalinfo.html)
> gdalinfo -noct N_197901_concentration_v3.0.tif
> #review source EPSG projection (found from gdalinfo command above)
> in web browser goto: http://epsg.io/3411
> #review desired output projection (lat/long)
> in web browser goto: http://epsg.io/4326
> #transform to NetCDF
> gdal_translate -f netCDF N_197901_concentration_v3.0.tif
> #reproject to lat/long, which is EPSG:4326
> (https://gdal.org/programs/gdalwarp.html)
> #examine reprojected file (verify "corner coordinates" look proper)
> gdalinfo -noct N_197901_concentration_v3.0_4326.nc
> * for all commands I used MS4W 4.0.1, on Windows, from https://ms4w.com
> Jeff McKenna
> On 2019-11-22 1:24 PM, Tony L. wrote:
> > Hello
> > I'm quite new with gdal and would like to use is to rewrite a geotiff of
> > NSIDC sea ice concentration from geotiff in polar stereographic
> > projection into a netcdf in Lon Lat coordinates
> > The file is located here: N_197901_concentration_v3.0.tif
> <https://www.dropbox.com/s/bkqt6qgyhpr7vjk/N_197901_concentration_v3.0.tif?dl=0>
> > Shared with Dropbox
> > I was able to transform the file into a netcdf file using gdal_translate:
> > gdal_translate -of netCDF N_197901_concentration_v3.0.tif out.nc
> > But I'm still trying to figure out how to translate this into Lon Lat
> > coordinates (probably using gdalwarp)
> > Any help would be really appreciated!
> > Tony
