[gdal-dev] Export a geotiff to netcdf in lat lon coordinates
Tony L.
tony_lst3 at yahoo.com
Mon Nov 25 12:11:48 PST 2019
Hello Jeff!Thank you so much for your help!!I tried to follow your steps and works well for the transformation from tif to netcdf. I can use ncdump to check info on the file and I can plot it normally.
Now, when I reproject the file to lat/lon coord using your command:
gdalwarp -s_srs EPSG:3411 -t_srs EPSG:4326 N_197901_concentration_v3.0.nc N_197901_concentration_v3.0_4326.nc
and when I try to get info on the file using ncdump -h I get:ncdump: N_197901_concentration_v3.0_4326.nc: NetCDF: Unknown file format
Any idea as to why that would happen?
Tony
On Friday, November 22, 2019, 01:19:50 PM EST, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
Hi Tony,
Here are my steps.
Have a nice weekend.
#use gdalinfo to get summary (see https://gdal.org/programs/gdalinfo.html)
gdalinfo -noct N_197901_concentration_v3.0.tif
#review source EPSG projection (found from gdalinfo command above)
in web browser goto: http://epsg.io/3411
#review desired output projection (lat/long)
in web browser goto: http://epsg.io/4326
#transform to NetCDF
gdal_translate -f netCDF N_197901_concentration_v3.0.tif
#reproject to lat/long, which is EPSG:4326
(https://gdal.org/programs/gdalwarp.html)
#examine reprojected file (verify "corner coordinates" look proper)
gdalinfo -noct N_197901_concentration_v3.0_4326.nc
* for all commands I used MS4W 4.0.1, on Windows, from https://ms4w.com
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2019-11-22 1:24 PM, Tony L. wrote:
> Hello
> I'm quite new with gdal and would like to use is to rewrite a geotiff of
> NSIDC sea ice concentration from geotiff in polar stereographic
> projection into a netcdf in Lon Lat coordinates
> The file is located here: N_197901_concentration_v3.0.tif
> <https://www.dropbox.com/s/bkqt6qgyhpr7vjk/N_197901_concentration_v3.0.tif?dl=0>
> Shared with Dropbox
> I was able to transform the file into a netcdf file using gdal_translate:
> gdal_translate -of netCDF N_197901_concentration_v3.0.tif out.nc
> But I'm still trying to figure out how to translate this into Lon Lat
> coordinates (probably using gdalwarp)
> Any help would be really appreciated!
> Tony
gdal-dev mailing list
gdal-dev at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191125/8d02dc4b/attachment.html>
