[gdal-dev] .kml to .xlsx or .xls ( with Geometry Column Included)
Wuyyuru Ravi Teja Krishna
ravitejakrishna.w at zohocorp.com
Wed Nov 27 04:45:06 PST 2019
Hello GDAL team,
We are trying to use ogr2ogr util for conversion of .kml to .xlsx. But the converted .xlsx file is missing geometry column. In documentation it says of using ogr vrt capabilities for this purpose but its not clear on procedure need to be followed. Can someone please direct us with solution to our problem?
Thanks in advance
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191127/bf02fe87/attachment.html>
