[gdal-dev] GDAL 3.0 Nuget packages...
Tamas Szekeres
szekerest at gmail.com
Thu Oct 3 06:49:23 PDT 2019
Hi Morten,
There have been problems with the GDAL 3.0 nuget versions, that's why that
was unlisted.
Specifically, the way how proj6 would want to find proj.db is not
satisfactory regarding to the C# applications.
I'm still working on a solution.
Best regards,
Tamas
Morten Breiner <morten at breiner.dk> ezt írta (időpont: 2019. okt. 3., Cs,
10:26):
> Hi,
> Currently, I am using GDAL 2.4.2 for some c# development in Visual Studio.
> I have installed the nuget packages found under
> https://www.nuget.org/packages/GDAL/2.4.2 (many thanks to all involved
> in maintaining those).
> From the download statistics
> (https://www.nuget.org/stats/packages/GDAL?groupby=Version), I can see
> that some attempt to support GDAL 3.0 has been made, but the packages
> have been unlisted unfortunately.
> Does any of you know if a release of nuget packages for GDAL 3.0 has
> been scheduled or as an alternative, if recommended GDAL 3.0 packages
> for c# can be downloaded elsewhere?
> Many thanks in advance for clarifying answers.
> BR
> -Morten Breiner
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191003/ba52e43e/attachment.html>
