[gdal-dev] Clarification on what is not addressed by GDALFlushCache
Sean Gillies sean at mapbox.com
Thu Oct 3 09:14:45 PDT 2019
In the comments above FlushCache() in gcore/gdaldataset.cpp it is said:
 * Using this method does not prevent use from calling GDALClose()
 * to properly close a dataset and ensure that important data not addressed
 * by FlushCache() is written in the file.
What exactly is the important data that is not addressed? Does it vary by
format and driver?
Thanks!
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191003/95dcfcdd/attachment.html>
