[gdal-dev] Clarification on what is not addressed by GDALFlushCache
Even Rouault
even.rouault at spatialys.com
Thu Oct 3 10:04:23 PDT 2019
On jeudi 3 octobre 2019 10:14:45 CEST Sean Gillies wrote:
> In the comments above FlushCache() in gcore/gdaldataset.cpp it is said:
> * Using this method does not prevent use from calling GDALClose()
> * to properly close a dataset and ensure that important data not addressed
> * by FlushCache() is written in the file.
> Does it vary by
> format and driver?
Of course, wouldn't be fun otherwise. For some formats, it might result in a
completely consistent dataset, and in others, in something that can't be
opened at all. So what is does, beyond evicting 'dirty' blocks from the cahce,
is mostly an implementation detail.
> What exactly is the important data that is not addressed?
In the case of GeoTIFF, FlushCache() will for example ensure that all tile/
strip data is flushed to disk, but the TileByteCount/TileOffset index arrays
are not updated, and os a file that was just created, they will be at their
zero default value, making the dataset appear to be empty to a reader that
would try to open it at that point.
If generating a large dataset, you can for example call FlushCache() at
regular intervals to make sure that there is sufficiently space on the storage
device (but the global block cache will also flush when it is saturated). This
might be a way of avoiding the memory to reach the GDAL_CACHEMAX threshold.
But this can also result in suboptimal behaviour if you call it at
inappropriate point. For example if you write to a JPEG-compressed tiled TIFF,
and your write pattern is row per row, then flushing before you reach a row
number that is multiple of the tile height, will flush partially written
blocks (their top will contain real data, and the bottom zeroes). So those
blocks will be later decompressed and recompressed, causing unnecessary
quality loss.
FlushCache() is automatically called by dataset destructor, so my tip would
be: "do not use FlushCache() unless you know you need it"
Even
http://www.spatialys.com
