[gdal-dev] What Statistics Are Returned By GDAL.Dataset.GetRasterBand(...).GetStatistics(...) ?
Peter Willis pwillis at aslenv.com
Thu Oct 3 10:21:58 PDT 2019
Hello,
I am using osgeo.gdal  python module  to load and get stats from image
bands.
While working with the, python, 'GetStatistics(...)' function I noticed that
the returned values seemed a bit off.
A snippet of code is shown below.
I compared the statistics returned in python by the function to band
statistics in ENVI image processing package for the same input file.
The results are shown below.
I am wondering if I am missing information regarding some key data filtering
feature in GDAL GetStatistics.
What statistics are GDAL returning?
## PYTHON CODE
src_ds = gdal.Open(image_path )
for bnd in range(1, src_ds.RasterCount+1 ):
    item = {}
    print("[ GETTING BAND ]: ", bnd)
    srcband=None
    srcband = src_ds.GetRasterBand(bnd)
    if srcband is None:
        continue
    bnddata=srcband.ReadAsArray()
    stats = srcband.GetStatistics( 0, 1 )
    if stats is None:
        continue
    else:
        print('put the values in a dictionary')
        ##GDAL stats##
        #item['min'] = stats[0]
        #item['max'] = stats[1]
        #item['mean'] = stats[2]
        #item['stdev'] = stats[3]
        ##numpy array stats##
        #item['min'] = bnddata.min()
        #item['max'] = bnddata.max()
        #item['mean'] = bnddata.mean()
        #item['stdev'] = bnddata.std()
#END PYTHON CODE
ENVI Statistics test returns these vales for each channel
Channel    Min            Max           Mean        Stdev
Band 1      0.000000  0.441641  0.135938  0.095007
Band 2      0.000000  0.477772  0.134556  0.096385
Band 3      0.000000  0.512614  0.143145  0.108702
Band 4      0.000000  0.574203  0.159381  0.128212
Band 5      0.000000  1.286870  0.190917  0.159562
Band 6      0.000000  1.368695  0.218191  0.191100
Band 7      0.000000  1.208142  0.179098  0.158407
GDAL GetStatistics in Python 3.0 Returns
{'min': 0.10543035715818, 'max': 0.35029646754265, 'mean': 0.19733288299107,
'stdev': 0.03141020073449},
{'min': 0.087364979088306, 'max': 0.36481207609177, 'mean':
0.19531263034662, 'stdev': 0.040193729911813},
{'min': 0.066563792526722, 'max': 0.40562310814857, 'mean':
0.20773722116063, 'stdev': 0.060965329408999},
{'min': 0.057971999049187, 'max': 0.49459338188171, 'mean':
0.23126556845189, 'stdev': 0.084854378172706},
{'min': 0.052771702408791, 'max': 0.57949388027191, 'mean':
0.27695694029464, 'stdev': 0.11419731959916},
{'min': 0.033055797219276, 'max': 0.67045384645462, 'mean':
0.31645853188616, 'stdev': 0.14756091787453}
Using NumPy Stats Functions in Python 3.0
np.min()
np.max()
np.mean()
np.std()
Return the following values after converting the previous GDAL bands to
'NumPy.Array' and using the NumPy functions
(Values look similar to ENVI)
{'min': 0.0, 'max': 0.44164082, 'mean': 0.13593808, 'stdev': 0.09500719},
{'min': 0.0, 'max': 0.47777158, 'mean': 0.13455594, 'stdev': 0.09638489},
{'min': 0.0, 'max': 0.51261353, 'mean': 0.14314489, 'stdev': 0.108702265},
{'min': 0.0, 'max': 0.57420313, 'mean': 0.15938139, 'stdev': 0.12821245},
{'min': 0.0, 'max': 1.2868699, 'mean': 0.19091722, 'stdev': 0.15956147},
{'min': 0.0, 'max': 1.3686954, 'mean': 0.21819061, 'stdev': 0.1911003}
