[gdal-dev] What Statistics Are Returned By GDAL.Dataset.GetRasterBand(...).GetStatistics(...) ?
Even Rouault
even.rouault at spatialys.com
Thu Oct 3 11:31:51 PDT 2019
On jeudi 3 octobre 2019 10:21:58 CEST Peter Willis wrote:
> Hello,
> I am using osgeo.gdal python module to load and get stats from image
> bands.
> While working with the, python, 'GetStatistics(...)' function I noticed that
> the returned values seemed a bit off.
> A snippet of code is shown below.
GDAL statistics take into account the nodata value (more exactly pixel whose
value equals the nodata value are ignored from the statistics). That might
explain the differences regarding the min, if 0 was the nodata value. But you
also get differences for the max value
Can you paste the output of gdalinfo on such a file ?
http://www.spatialys.com
