[gdal-dev] Adding The DWG Driver to ogr2ogr?
Alan Snow alansnow21 at gmail.com
Tue Oct 15 17:06:15 PDT 2019
Hi Brandon.
I would recommend opening up an issue on the conda-forge feedstock:
https://github.com/conda-forge/gdal-feedstock
Best,
Alan
On Tue, Oct 15, 2019 at 4:00 PM Brandon Biggs <brandon.biggs at ski.org> wrote:
> Hello,
> I'm wondering how to build custom packages to use in my Conda installation?
> In particular, I would like a GWD driver for ogr2ogr.
> I would like the AutoCAD DWG driver
> <https://gdal.org/drivers/vector/dwg.html>, but it looks as if it is not
> built in my installation.
> It looks as if I will need to edit the make file and run a custom build to
> get the driver. I searched the docs and Github for building instructions,
> but don't see any.
> The instructions for "hand editing" the GNUmakefile don't say what to
> change, and I'm not exactly sure where "paths" is and what to do with it.
> The fact I'm supposed to build the driver as a plugin gives me hope though
> that I can find the built plugin somewhere and just insert it into some
> plugins folder in my Conda build.
> What would be the best steps from here?
> Thank you,
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Alan Snow
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191015/77a517ae/attachment.html>
