[gdal-dev] Adding The DWG Driver to ogr2ogr?
Brandon Biggs
brandon.biggs at ski.org
Tue Oct 15 17:29:12 PDT 2019
Hello,
I opened an issue:
https://github.com/conda-forge/gdal-feedstock/issues/339
Please let me know if there is something else I can do.
Thank you,
Brandon Biggs<https://www.ski.org/users/brandon-biggs>
Engineer
Smith-Kettlewell Eye Research Institute
Office: 415-345-2130
Cell: 650-833-9394
Sent: Tuesday, October 15, 2019 5:06 PM
To: Brandon Biggs <brandon.biggs at ski.org>
Cc: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Adding The DWG Driver to ogr2ogr?
Hi Brandon.
I would recommend opening up an issue on the conda-forge feedstock: https://github.com/conda-forge/gdal-feedstock
Best,
Alan
On Tue, Oct 15, 2019 at 4:00 PM Brandon Biggs <brandon.biggs at ski.org<mailto:brandon.biggs at ski.org>> wrote:
Hello,
I'm wondering how to build custom packages to use in my Conda installation?
In particular, I would like a GWD driver for ogr2ogr.
I would like the AutoCAD DWG driver<https://gdal.org/drivers/vector/dwg.html>, but it looks as if it is not built in my installation.
It looks as if I will need to edit the make file and run a custom build to get the driver. I searched the docs and Github for building instructions, but don't see any.
The instructions for "hand editing" the GNUmakefile don't say what to change, and I'm not exactly sure where "paths" is and what to do with it. The fact I'm supposed to build the driver as a plugin gives me hope though that I can find the built plugin somewhere and just insert it into some plugins folder in my Conda build.
What would be the best steps from here?
Thank you,
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
Alan Snow
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191016/f6920196/attachment-0001.html>
