[gdal-dev] Adding The DWG Driver to ogr2ogr?
Even Rouault
even.rouault at spatialys.com
Wed Oct 16 01:02:43 PDT 2019
On mardi 15 octobre 2019 19:06:15 CEST Alan Snow wrote:
> Hi Brandon.
> I would recommend opening up an issue on the conda-forge feedstock:
> https://github.com/conda-forge/gdal-feedstock
Do you realize that the DWG driver requires a proprietary (& non-gratis) SDK ?
The alternative is the CAD driver (https://gdal.org/drivers/raster/cad.html)
but it probably doesn't support everything of the DWG one
Even
http://www.spatialys.com
