[gdal-dev] Adding The DWG Driver to ogr2ogr?
Alan Snow
alansnow21 at gmail.com
Wed Oct 16 05:29:20 PDT 2019
Ah, then that definitely won't work with conda-forge. Thanks for
pointing that out.
On Wed, Oct 16, 2019, 3:02 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> On mardi 15 octobre 2019 19:06:15 CEST Alan Snow wrote:
> > Hi Brandon.
> > I would recommend opening up an issue on the conda-forge feedstock:
> > https://github.com/conda-forge/gdal-feedstock
> Do you realize that the DWG driver requires a proprietary (& non-gratis)
> SDK ?
> The alternative is the CAD driver (
> https://gdal.org/drivers/raster/cad.html)
> but it probably doesn't support everything of the DWG one
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191016/a97b9de9/attachment.html>
