[gdal-dev] Converting 3D Polygons to 2D Polygons?
Eli Adam
eadam at co.lincoln.or.us
Tue Oct 15 19:14:10 PDT 2019
On Tue, Oct 15, 2019 at 6:12 PM Brandon Biggs <brandon.biggs at ski.org> wrote:
> Hello,
> Is there some way to convert 3D objects to 2D polygons using ogr2ogr?
Did you already try, -dim XY
More details here,
https://gdal.org/programs/ogr2ogr.html#ogr2ogr
What happened if you tried -dim XY?
Best regards, Eli
I have a large file with lots of polygons with 0 as the z coordinate. So
> the point would look like [1,2,0].
> I would like it to be: [1,2].
> Thanks,
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191015/79294943/attachment.html>
