[gdal-dev] Filtering Null Coordinates and rounding coordinates Using ogr2ogr?
Brandon Biggs brandon.biggs at ski.org
Wed Oct 16 15:14:56 PDT 2019
Hello,
This doesn't seem to work. Thank you for the SQL link.
I am wondering if these warnings have anything to do with the null geometries?
Warning 1: Block Bloc truss 16X16X8 does not exist
Warning 1: Block Bloc TRUSS CUBE 16X16 does not exist
Does anyone know what may cause these errors and if they may be causing the empty geometries? Also, why would -skipfailures=true not skip these warnings?
Thank you,
Brandon Biggs<https://www.ski.org/users/brandon-biggs>
Engineer
Smith-Kettlewell Eye Research Institute
Office: 415-345-2130
Cell: 650-833-9394
Sent: Wednesday, October 16, 2019 2:54 PM
To: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Cc: Brandon Biggs <brandon.biggs at ski.org>
Subject: Re: [gdal-dev] Filtering Null Coordinates and rounding coordinates Using ogr2ogr?
On mercredi 16 octobre 2019 21:29:41 CEST Brandon Biggs wrote:
> Hello,
> I have two questions with ogr2ogr:
> How do I remove features that have a null geometry?
> I tried:
> -where "\"geometry\" != null"
-where "OGR_GEOMETRY is not null"
--> https://gdal.org/user/ogr_sql_dialect.html#special-fields
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191016/df83cf9b/attachment.html>
