[gdal-dev] Filtering Null Coordinates and rounding coordinates Using ogr2ogr?
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Thu Oct 17 02:37:37 PDT 2019
Works for me. Here is my test data, copy and save as "empty.jml"
<?xml version='1.0' encoding='UTF-8'?>
<JCSDataFile xmlns:gml="http://www.opengis.net/gml"
xmlns:xsi="http://www.w3.org/2000/10/XMLSchema-instance" >
<JCSGMLInputTemplate>
<CollectionElement>featureCollection</CollectionElement>
<FeatureElement>feature</FeatureElement>
<GeometryElement>geometry</GeometryElement>
<CRSElement>boundedBy</CRSElement>
<ColumnDefinitions>
</ColumnDefinitions>
</JCSGMLInputTemplate>
<featureCollection>
<gml:boundedBy>
<gml:Box>
<gml:coordinates decimal="." cs="," ts=" ">380.00,320.00
380.00,320.00</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<feature>
<geometry>
<gml:Point>
<gml:coordinates>
380.0,320.0
</gml:coordinates>
</gml:Point>
</geometry>
</feature>
<feature>
<geometry>
<gml:Point>
</gml:Point>
</geometry>
</feature>
</featureCollection>
</JCSDataFile>
The commands to run
List all geometries, including empty ones:
ogrinfo empty.jml -al
Filter out empty geometries with OGR SQL dialect:
ogrinfo -where "OGR_GEOMETRY is not null" empty.jml -al
Filter out empty geometries with SQLite SQL dialect:
ogrinfo -dialect SQLite -sql "select * from empty where geometry is not
null" empty.jml
Filter out empty geometries and scale coordinates with SQLite SQL dialect:
ogrinfo -dialect SQLite -sql "select ScaleCoordinates(geometry,0.0254) from
empty where geometry is not null" empty.jml
Changing the decimal precision does not seem be simple with SpatiaLite so
you must do it with org2ogr. Use -dsco COORDINATE_PRECISION=2 as documented
in https://gdal.org/drivers/vector/geojson.html.
ogr2ogr -f geojson -dialect SQLite -sql "select
ScaleCoordinates(geometry,0.0254) from empty where geometry is not null"
round.json -lco coordinate_precision=2 empty.jml
Did I pass the test?
Recommended reading
http://www.gaia-gis.it/gaia-sins/spatialite-sql-latest.html
-Jukka Rahkonen-
Brandon Biggs wrote
> Hello,
> This doesn't seem to work. Thank you for the SQL link.
> I am wondering if these warnings have anything to do with the null
> geometries?
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
